Audio only
DG0507
Audio only
Intermittently I have a 'Audio only' sign on my Bravia TV (KD 49XF7596) How do I remove it? Thanks
3 REPLIES 3
LightFoot
Specialist
Hi @DG0507   What are you watching (from what source) when it appears?
DG0507
Hi, it's on digital. It generally happens when watching iplayer, ITV hub etc. It also comes up on general channels as well. Thanks
comorri50
I have just bought the KD-43XG8305. It's very annoying when on a radio channel. Even a radio channel that has a picture. Why can't it be cancelled? Example:
As you can see, it covers some of the text.
Even worse, if the channel is a radio channel when you go to BBC iplayer, you get this:
YXhUEZi
Not good. Time for a return/refund? Can it be fixed with firmware? Is there a button that I can press?
