Assistance please.....My Sony Bravia KD-43XE8005 which I bought just over two years from John Lewis has recently started giving me Audio Descriptions, which I do not want. I have read a lot of the messages here and have tried to switch it off but to no avail. It is becoming annoying and frustrating and from what I can see here many different Sony TV sets seem to have many different configurations? I am finding it all quite baffling for something that should surely be a basic setting? The software and firmware (?) are both up to date. I have been into the settings menu (numerous times) and cannot see an on/off for Audio Descriptions and the one place it is mentioned is set to normal, as recommended in another post. I have disabled the Auto Service Update and then enabled it again after checking for updates, again as recommended in another post. Our TV services are provided by Virgin Media. I am in the dark and do not understand much of the 'jargon'.
Can anyone help me please?
Thank you,
John
Hi @JofnaTV
Just to be clear, are you getting AD when watching Virgin Media or Terrestrial channels on the TV?
Thank you for your reply. I always watch through the Virgin Media box. An external aerial is connected to the TV but not used. John
That is great thank you very much!
I did say I found it baffling and I am now on my way to try this link!
Fingers crossed....
Brilliant thank you, that is the answer! Your help was most appreciated.
