Apps not loading KDL 40WE663
glenn.hodson
APPS NOT LOADING, SOFTWARE UP TO DATE AND NETWORK CONNECTED AND OPERATING. TV ONLY ONE MONTH OLD. IS THIS A KNOWN FAULT?
3 REPLIES 3
Pascale_F
Moderator
Hi Glenn,
I'm just going to try to find some answers for you. In the meantime, maybe someone else in the community might have some ideas.
Thanks,
Pascale
The_Black_Rose
Specialist
Hi glenn.hodson,
I think this may be related to the network connection. Have you tried connecting your TV to a different network like a hotspot from your mobile phone on 4G?
Cheers,
The_Black_Rose
glenn.hodson
Network connection OK, ended up reset to factory settings to sort problem out.
