отмена
Отображаются результаты для
Вместо этого искать
Вы имели в виду:
Alexa on kv 55a1
profile.country.DK.title
raekkermoelle
Исследователь
Alexa on kv 55a1
On my KD-55a1 there is no control app on the home screen for Alexa. I read on Sonys homepage that the TV was able to be controlled by Alexa but how?
1 ОТВЕТ 1
EdwinaU
Moderator
Hi there,
Please check that you have the latest firmware on your TV. It introduces compatibility with Amazon Alexa compatible devices (UK only). You should then be able to run the 'TV Control Setup with Amazon Alexa' app.
Best wishes,
Ed
