65xg9505 Problems
profile.country.RO.title
Mikhail_vio
65xg9505 Problems
Hello. Each time I start the TV, this expensive TV, this TV do not start thr TV function : the image is black. I have to do it again or to restart it. Also if I connect HDMI, laptop, same issue!
Why??
5 REPLIES 5
Hi Mikhail_vio,
Is your TV running the latest software?
https://www.sony.co.uk/electronics/support/lcd-tvs-android-xg95xx_x95xxg-series/kd-65xg9505/download...
Peter
Mikhail_vio
The tv have la la test updates
Sent from Yahoo Mail on Android
Joe_Dohn
Specialist
Have you tried disconnecting everything from the TV and unplugging it from the mains for 2-3 minutes to depower the set?
Mikhail_vio
Hello. The issues continue: youtube sometimes is blocking, and only restart solve it, and when I use hdmi from laptop I have to try for 2 Times or to unolug the hdmi cable, and sometimes when I switch to TV the screen is black.
Joe_Dohn
Specialist
Have you tried clearing cached data (Settings - Device Preferences - Storage - Internal Shared Storage - Cached data) or resetting the TV (Settings - Device Preferences - Reset) ?
