muvoda
55XH SERIES TO PS2
Hi guys, I have a new 55XH9505 tv and I wanted to connect a PS2 to it but I can only find 2 coloured inputs on the left side of the tv and both seem to be too big for the PS2 connector's to stay in the holes plus there is only 2, whereas the plug on my PS2 has 3 coloured connection's, is it at all possible for my PS2 can be  connected to this tv? or do I need to purchase some kind of extra connector. Cheers all. Regards muvoda.
muvoda
Hi Peter, thank you for your reply, I'm sorry but I haven't got a PC, I was referring to a tv, all I can see by the hdmi inputs are 2 round coloured inputs wearas my PS2 has 3 coloured male connectors, (my PS2 connectors seem too thin they don't fit snug, the tvs inputs seem too wide) so if I need to buy an adapter to connect to one of the HDMI ports then I will have a look around for something. Kind regards muvoda.
2 REPLIES 2
Since the PS2 uses analogue connections you cannot connect it to your PC without an adaptor.
You would need an analogue to HDMI adapter to connect the PS2.
Peter
muvoda
