This is a very detailed query but I need some help with the USB-C to Micro USB cable used to charge the Sony a6400 battery, connect to PC, etc. I know its important to use the right cable - and in particular the one supplied with this camera. I have managed to mix up my cables. What are the distinguishing markings on the USB C to Micro USB cable supplied with the Sony a6400 camera? One of the cables I have got has LUXSHARE-ICT printed on the cable (as well as some other markings) and has the letter 'B' embossed on the Micro-USB jack end. Is this the one that comes with the camera? Thanks in advance for your help
Sadly, it's a little difficult to find that out over the community since it's most likely that only someone who has your exact camera would be able to answer that.
Try reaching out to the Sony support reps for more identifiable details about the cable, that's probably your best bet.
Hope this helps!
- JD
