Hello
I'm having a trouble with my external mic. It works well with other devices. But I hear noise in the videos recorded with my camera.
Here is a video example: https://youtu.be/zs2yKlxbkJA
Thank you for any suggestions about this issue.
Does this happen on the latest software version for you?
Yes, I have 1.03. Is this the latest version?
According to the support page, it is the latest, yes.
Have you tried resetting the camera or using a different external microphone?
- JD
Resetting didn't help. I've tried a mic from my headphones. It works better. It's strange because the camera mic works fine on PC. I think the problem is with audio levels, I can't find any settings about this.
Hey tarchuiko , which mic are you using?
