Cameras System Recommendations
mcmjuk
I contacted Sony via FB looking for pre sales recommendations and they sent me here!!!!!!
I am currently planning a photographic projects which will see me working in some challenging environments and weather conditions over a period of 3 years. As a result I am looking for a camera system that is robust, reliable will allow me to work in the field seamlessly.
I would be grateful if you could recommend from your range a system using the following requirements.
If you have any questions please do not hesitate to contact me.
Kind regards
Simon
www.mcmj.co.uk
Camera system's working environment:
  • High Street
  • Industrial
  • Land / Sea Scapes
  • Churches Interiors and Exteriors.
  • All weathers
  • All seasons
  • Indoors with available light only. (No flash)
Camera System Equipment required:
  • 2/3 x lenses as per the specifications below.
  • 2 x Camera bodies as per the specifications below.
Camera system requirements
Essential
  1. Lens focal length range of 16mm – 200mm (35mm Full Frame equiv) split over two / three lenses.
  2. Lens maximum aperture of F4.
  3. Weather Sealed and dust proof camera body and lenses.
  4. 20 megapixel sensor or greater.
  5. Image Stabilisation on Camera / and or Lens.
  6. Ability to capture and produce clean images up to ISO 3200 at a minimum.
  7. Ability to customize dials for exposure compensation and aperture control.
  8. Ability to bracket 3/5 exposures from 0.7 to 1.5 of a stop.
  9. Ability to capture RAW.
  10. Metering options: Multi-segment, Centre-weighted, and Spot.
Nice to have but must not compromise Essential requirements
  1. Dual memory card slots.
  2. Electronic Shutter Options
  3. In camera focus stacking / bracketing.
  4. Manual Focus Peaking.
  5. Depth of field preview.
2 REPLIES 2
profile.country.NL.title
Strampke
I'd say try here.
mcmjuk
I am aware of the independent reviews I am looking for Sony's recommendations specifically.
Si
