I have scratched the lens on my HDR-AS100V, just wondering if I can get it repaired or replaced, I emailed support, but not got a response from them, anybody any ideas?
any help would be much appreciated!
You should cary your action cam to a repair center.
Think you can find one next to you using this search tool: http://services.sony.co.uk/support/en/repair/asc
PD
