RX0 with control box - save images to networked drive
c_h_r_i_s
Hi all,
I have an RX0 connected to a control box. Is it possible to save images directly to a drive my PC (which is directly connected to the control box through a LAN cable) instead of using the webapp to import them from the SD card?
Thanks!
2 REPLIES 2
Pascale_F
Moderator
Hi Chris,
Welcome to the community.
I'm just going to try to find some answers for you. In the meantime, maybe someone else in the community might have some ideas.
Thanks,
Pascale
c_h_r_i_s
Hi Pascale,
Any luck with this?
Thanks,
Chris
