HDR-AS50 TImelapse problem
robert90903
Hello
I am planning a long timelapse using a HDR-AS50 camera but have come across a problem during testing, it seems to be limited to 40,000 shots
i have used a 128GB memory card, and when i put the memory card in the camera it said 40,000 shots reamining, i left it running and it took exactly 40,000 shots, and wont allow any more to be taken, but there is 70GB free on the memory card, so i dont understand the 40,000 limit and is there anyway around this problem?
Thank you
3 REPLIES 3
Marino.Manolo
https://helpguide.sony.net/cam/1640/v1/en/contents/TP0000960294.html
Hint
  • The maximum number of continuous shots is 40,000.
    Manolo
robert90903
ah so no way of getting around it i assume
IamNic
Hello @robert90903,
unfortunately the limit is there, since some SD-cards can't handle significantly more files than fourty thousand.
There are a few trick though: https://www.reddit.com/r/sonyactioncam/comments/9hdktk/getting_rid_of_40k_max_photo_limit_on_x3000/
- Nic
