HDR-AS15 high speed movie problems
kew356
Hi
when is use the cam with 120fps setting and import the movie into Final Cut on a Mac
the movie frame rate is only 60fps and not the orignal 120fps
is this a problem from the camera meta data or ?
Best Regards
Tags (1)
1 REPLY 1
profile.country.de_DE.title
cmosse
Contributor
I think this is due to the meta data which is contained in the movie file. While the actual frame rate of the recording is in fact 120fps the info will still show 30fps (e.g. with VLC media player or the MediaInfo software)MediaInfo - HDR-AS15_120fps shown as 30fps.png.
