FDR-X1000v won't turn on, REC-LED is blinking
Johndeere87
Hey
I'm running out of luck regarding a problem with my Sony FDR-X1000v.
I've been using it for about a year when suddenly it stopped working, when I put in the battery the REC-LED blinks in a specific pattern: 3 Long 7 Short ---.......
I've made a short clip describing the problem
https://www.youtube.com/watch?v=TKYq_P6I4Qk
I have no idea of what this blinking means - and I can't seem to find anything online.
I've tried a lot of different things everything ends with the blinking, here is some of the thing I've tried:
  • With and without SD-card
  • Different SD-Cards
  • Other batteries
  • Holding down buttons when putting in the battery
  • Connecting it to the PC (with and without battery)
Connecting the camera to a PC, I hoped I could re-flash the firmware, but because the camera never turns on it is not recognised by the PC. It just blinks the REC-LED when I connect a USB-cable.
The camera is within the 2 year warranty, but I can't find my receipt, hence Sony won't make a repair.
Does anyone of your guys know how to solve this problem?
Thank you
Regards
Johndeere87 aka. JD
PS: I've posted the same message on reddit:
https://www.reddit.com/r/sonyactioncam/comments/8lk1q0/fdrx1000v_wont_turn_on_recled_is_blinking/
Update: I was told I need a new main board, it would cost more than a new camera to replace. Decided the camera was dead, not worth repairing. Camera was working fine until suddenly it wasn't anymore, not I get no reaction from the camera when I put in the battery, other than the blinking LED ...
4 REPLIES 4
IamNic
Hi there @Johndeere87,
first off - thank you for the detailed explanation of your issue, people rarely give so much detail (if any at all).
Since I don't know how to resolve your issue, I will forward this issue to the support.
I will give you an update as soon as the support replies back to me.
- Nic
IamNic
Hello @Johndeere87,
The support checked your post and advices the following:
I checked the post and you have already tried all the relevant trouble shooting steps so the only thing left is to send it to our service for inspection/repair. If you don't have a VAT invoice to confirm the warranty status you can get back to the retailer and request one.
Just a heads up - in the UK the warranty periode is one year starting the date of purchase.
Thanks,
Batikh
- Nic
Johndeere87
Hello
Thank you for you help.
Problem is that the retailer went out of buisness in the meantime - so I cannot get an invoice copy from him.
In Denmark (where I live) there is a two year warranty periode.
IamNic
you should be able to issue a repair via this site: http://services.sony.dk/supportmvc/da/repair?cpint=spt-footer_repair
- Nic
