Vaio SVE171E13M
Jeanw1
Vaio SVE171E13M
The optical drive on my Vaio SVE171E13M is not playing discs. Any suggestions please?
5 REPLIES 5
Pascale_F
Moderator
Hi Jean,
Welcome to the Community. You'll need to contact Sony Support about this.
Thanks,
Pascale
Marino.Manolo
Try clean the Optical Lens with a soft small brusch... Or with a Cleaning Disk (without liquid)...
Jeanw1
Thank you Marino,
I have tried this and the disc still doesn't play. I appreciate you advice, thanks again.
Jeanw1
Hi Pascale,
Thank you for your advice, I have tried this and so far have not found a solution. I much appreciate your help.
I have since ordered a USB optical drive, which also does not play discs. This I find very strange as when I look in device manager at properties on both, it shows that they are working properly? Maybe it is something on my laptop that needs changing?
Thanks again.
Jeanw1
Also, I am using Avast security, maybe there is something in the settings that is denying access? Just a thought.
