Sony Vaio
bitemylip
Sony Vaio
I have a Sony Vaio laptop that I bought 8 years ago. The battery needed replacing about 2 years ago and as Sony don't appear to do them anymore I bought a generic one that said it was compatible. It worked fine, but now also appears to need replacing. Any suggestions as to what/where to purchase a better/decent one?
3 REPLIES 3
Joe_Dohn
Specialist
What model Vaio do you have?
bitemylip
Hi Joe, it's a SVE1513A4E.
Joe_Dohn
Specialist
According to the specs, the battery model number is VGP-BPS26, I found it in stock at EET.
You might wanna save this thread for future reference.
Hope this helps!
- JD
