help with sony laptop
sebmalde
Hi I have a old sony laptop that will not boot. when i try to do recovery after a while it comes with a list of files . once i chose the dat files to back up to sd drive it starts rescue and then says error occurs when rescuing data and ends. any one can help?
3 REPLIES 3
Joe_Dohn
Specialist
Can you share the model number of your laptop and possibly an unlisted YouTube video of what you're describing so we have a better idea of what's going on?
sebmalde
model number is sony vaio pcg71511m
Joe_Dohn
Specialist
I couldn't find a support page for that model. Can you double-check you have the correct one?
