Burning CDs/DVD/s
induct
Burning CDs/DVD/s
I want to use B's Recorder Gold 5 but when I load up it can't find the CD/DVD Drive. When I go to options the drive selector is hidden. Any ideas? Are A series DVD drives not compatable with some softwares?
P.S. I don't want to use Nero!
9 REPLIES 9
profile.country.en_GB.title
kee-lo_
Hi
It's missing the ASPI drivers, thats all.
See this
induct
Cheers for the reply, installed the adaptec XP32. (does adaptec control drives?)
Unforunately still not working.
kee-lo_
Is that the ASPI layer?
induct
kee-lo_
That should be fine.
No idea why that software isn't working...
induct
What supplied software should I use for burning DVD/CD's?
My fiends S1XP has something called Drag n' Drop, why don't the A series have this?
kee-lo_
I thought it did...
induct
These are the only progams on my PC:
Programs on PC
The A197XP has Drag 'N' Drop according to here:
http://www.vaio-link.com/specifications/specifications.asp?l=en&m=1547
But the A297XP Doesn't
What should I do?
induct
Ok found what to use:
"Sonic RecordNow!"
