recording on kdl 32ex532
panehenry
Trying to connect a HDD to enable recording on the kdl 32ex532.
Is the recording option available in Ireland? Apart from formatting the HDD to NTFS is there anything I could check?
Thanks in advance
1 REPLY 1
Anonymous
Hi there
Not sure about recording in Ireland.  But HDD needs to formatted to FAT32
But the more pertinent question is, your TV model number?  Is it KDL-32EX532 or KDL-32EX523?  Reason I ask is because I dont think that there is a EX532 model, but there is a EX523.
Assuming that you have the KDL-32EX523
I have been taking a look at the manual for the EX523 model, and I can see that it has 2 USB ports.  Neither one of them is labled HDD.  This suggests to me that you cannot connect a USB HDD to this TV and record TV.  Looking at the manual futher, there is nothing in their to state USB HDD recording.
According to the specifications of the EX523 : HERE
There is a line next to USB HDD recoding (suggesting it is not supported)
A futher google search gives very mixed results, but I believe that the EX524 supports USB HDD recording
Therefore Im concluding that it is not possible for the EX523 model (unless further evidence suggests so)
Sorry to be the barer of bad news.
